Hello all
I am not new at this, have done it a million times (with other devices) but my Sumvision Micro4 just refuses to work with the wired connection. I know there's nothing wrong my RJ45 cable because I was using it with my xbox360 and it's using the same router as everything else. I have my PC, NAS drive and work laptop to the same router and it all works!!
The micro4 just says Connection Failed, despite having tried both Auto and Manual options.
I am using a fairly old Linksys Router (WRT54GS with firmware v1.50.6 ) but it's the first device I've come across which refuses to work with it. Note that there is no later firmware for this router.
The odd thing is that it works fine with WiFi from the same but I am not particularly happy with the performance.
Any tips would be appreciated. Also, how does their support work? I've filled in the form but I am not seeing an obvious way to contact them.
thx
dAVID
thx
dAVID
