TB Rich
Has anyone used one of these cables successfully to connect from stereo pre-outs to a mono subwoofer input?
(I don't want to connect only the L or R before anyone suggests).
Summing Cable
This cable is sold and positioned as being needed for use with an Antimode when sharing a Hifi amp and AVR:
I suspect it'll work fine as other than the fact I'm connecting to a miniDSP and not an Antimode - I'm using it as intended. However not being entirely literate on the engineering side of things I just want to do a bit of due-diligence and make sure it won't damage anything!
My basic understanding of the subject is line level outputs are low impedance, whereas inputs are high - and you therefore can not use a basic Y cable as it would effectively tie the 2 outputs together.
What I'm not sure on is this: given a 10k resistor on each channel, does that make it an effective 20k? And then given the miniDSP input is 10k - is that then a problem?
Summing Cable
