Suiteable Digital tv aerial?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by noveed2006, Mar 20, 2003.
  1. noveed2006
    noveed2006
    Anyone here an expert on roof aerials. Any advise?
    should i specify a paticular make/model considering i will have integrated digital tv [idtv/freeview]
    I live in the midlands and if anyone has recently had one put in or upgraded can give me a rough idea on how much i should pay for one including installation
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,808
    2
    167
    Birmingham, UK
    +9,527
    This thread should be in the Digital TV and Satellite forum.
    Moving it...
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    What town / area are you?
    For Sutton Coldfield you will need a wide band aerial as channels are covered from 40 to 55
    Look for a good aerial installer who doesn't keep pushing Sky
  4. Fernsehman
    Fernsehman
    Depends on how long the job takes but expect to pay a minimum of £45 for, say, 90 minutes work plus the cost of the aerial, cable (double-shielded) and VAT.
    Check out the CAI registered installers directory:-
    http://www.cai.org.uk/cgi-bin/cai.storefront
    Or the Association of Professional Satellite Installers:-
    http://www.apsiuk.com
    (They specialise in non-Sky dish installations but many of also specialise in aerials and some will do Sky if you ask them to).
    For any DIY enthusiast, read The Freeview Bible .
    Fman
  5. noveed2006
    noveed2006
    thanks for the replies.
    i live in walsall by the way.
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Walsall
    A decent 4 foot or so W roof mounted with CT100 cable will be fine
  7. Fernsehman
    Fernsehman
    Ah, in that case phone EUROSAT and ask them whom they recommend. They supply all the local aerial installers so they'll know who is competent.
    Tel: 639299
