Suitable Sub
Discussion in 'Subwoofers' started by fatrich, Oct 25, 2001.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,613
    71
    halifax
    +53
    Hello All
    The new look forum looks great by the way.
    Having just spent a small fortune on the Kef Thx package with x2 set's of rears i am now needing a decent sub.At the mo i have the Rel Q200e which for it's size is very good i feel i need something with a little more guts, i did't go for the big Kef sub because some say it's a little over rated and over priced, would another Q200 be a wise move or should i go for something like M&K 150Thx or the 350Thx ? can anyone offer suggestions or advise i would appreciate it.
    Just to add the system is for movies and not aimed at music.
    Many thanks
    richard
