Suitable stand for older TV
smallzoo
I have an older Panasonic 42 " tv ( TX-P42X50B ) with was on the wall and now needs to be on a stand. We dont have the stand and I'm not sure which stand would fit.
Obviously being an older TV its going to be difficult to find the exact stand and if it was available probably expensive so wondered if any sort of generic stand would fit
cheers
Rodders53
You'd be looking at a universal VESA mount table top or floor stand to suit the dimensions and weight (check the manual) of the TV. Depending on what you want.
Examples from one company (not a recommendation, never used them) panasonic TV Stands Suitable for panasonic 42 inch ALL MODELS TV
Other stands and other suppliers are available.
Check out second hand auction sites too - you may consider the price acceptable, if one is available, compared to something generic.
