Suitable Speaker,Sub & Amp Setup
Discussion in 'Subwoofers' started by slyborg, Aug 17, 2003.
  1. slyborg
    slyborg
    Jun 16, 2003
    152
    +4
    I'm upgrading my system from a Yamaha 795 amp and Bose AM10s (I was young naive and flush with cash ok!!)
    So my room is approx 15m x 12m and I'm looking at the following:
    Pio VSX-D2011-S
    SVS sub 20-39 or 25-31
    B&W VM1 x 5 (Dont have space for anything floor mounted etc.
    Anyway demoing the lot will be hard (impossible with the SVS) so I have a few questions for those in the know or with similar equipment/room sizes
    One thing though is I want to have something that when I move to a larger place means that I can get away with say just upgrading say the B&Ws
    1. Is the SVS overkill
    2. Is the amp going to be too powerful
    Any other comments welcome
    Si
  2. Smurfin
    Smurfin
    Aug 13, 2002
    20,659
    +4,017
    Si
    I'm guessing you mean 15' x 12' rather than metres? (if not then you have a bloody huge room!)
    In answer to your questions:
    1. SVS overkill? No way. Even if your room was smaller, the fact is you'd be buying a sub which you wouldn't need to upgrade in a long time...even if you moved to a bigger place. Good move.
    2. No again. The amp will be fine.
    Re: your comments on not having space for floorstanders: with an SVS sub you only need standmount speakers anyway...the SVS will be more than capable of plugging the sub 80hz void:)
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I assume that the measurements should be feet and not metres.
    Neither the subwoofer nor amp are overkill as power in hand is as useful in an AV scenario as it is for motoring.
    They would be the equivalent of driving a powerful car on the motorway at 70 mph
  4. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    If you are keen on demoing stuff....... you should think about the servo 15 sub as well as the svs...... you can buy one from RS and you have a full 30 days in which you can demo it and return.....
    Ad
  5. slyborg
    slyborg
    Jun 16, 2003
    152
    +4
    Ooops yeah feet not metres, thanks for the comments
