Question Suitable small presence speakers
Discussion in 'What Speakers Should I Buy?' started by HouseofMu, Apr 27, 2016.
Tags:
  1. HouseofMu
    HouseofMu
    Jul 18, 2000
    377
    UK
    +13
    My lounge/home cinema surround consists of B&W FPM speakers (FPM6 for FL, FR, Center and FPM5 for RL, RR - they are wall flush mounted) and I'd like to add two front height speakers (known as "presence") from a Yamaha V3900 7.1 channel amp.
    I've been looking around for a pair of FPM2's as they're small and would match (aesthetically and sonic-ally) but are proving hard to buy second-hand (typically £120-150 ish) so I'd like recommendation for alternatives ?
    Speakers with similar to the FPM2 specs (8ohm, 100w, 80Hz - 20kHz freq) but considerably cheaper (new) I've come across are:
    Q ACOUSTICS 2010i GR £99 (has better freq response of 68 - 22,000)
    JBL CONTROL 1 £79
    Ideally I don't want large bookshelf speakers, but would I notice the quality difference on those channel?
    Any suggestions ?
    I assume such front channels are of a limited freq response anyway? Is this still the case with Atmos, would they still be suitable if I upgrade to that, (and add more Side speakers etc)?
    Any thoughts?
  2. Marc71
    Marc71
    Jun 8, 2016
    15
    4
    Europe
    +6
    For on-wall mount I highly recommend the DLS Flatbox range of speakers and subs.
    You can find many pics and technical tips in my article.​
