Gunmaster G9
what would be a suitable screen type for the above projectors?
max budget with projector and screen is around £1000, maybe pushing higher if really needs be but want to keep to £1000 max.
The screen will be roof mounted and it is going in the main living room. Will mainly be used for movies, majority of times late evening. Only source will be used is either bd player or hd media player with bd-iso movies.
the walls are all painted white. And looking through different calculators max size i can have at a push will be 120".
would i need a white or grey background screen? I will be viewing movies both in 2.35 & 1.78 ratios.
all advice is appreciated.
Thank you in advance.
Haroon
Haroon
