Suitable Pre Amp for Technics SL-D21 turntable
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Technics Scott, Feb 12, 2009.
  1. Technics Scott
    Technics Scott
    Feb 12, 2009
    5
    4
    Kent
  2. Technics Scott
    Technics Scott
    Feb 12, 2009
    5
    4
    Kent
    Testing signiture, lolz
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,335
    +4,209
    Well, the first thing to do is check and see if your all-in-one has a PHONO input, if it does, it's a done deal. You've got everything you need.
    If not, and assuming the Turntable does NOT have it own built-in pre-amp, then this pre-amp is probably as good as any.
    You could try going to or calling Richer Sounds to see if they have any other recommendations.
    So -
    Check to see if you amp has a PHONO input, if so, your cool.
    Check to see if your Turntable has it's own built-in pre-amp, if so, your cool.
    If not, then you need to buy an external pre-amp, and if £20 is your budget then this is probably OK.
    Steve/bluewizard
  4. Technics Scott
    Technics Scott
    Feb 12, 2009
    5
    4
    Kent
    Thanks Steve, I don't think they are phono sockets on the all-in-one, as it just says AUX on them, and I know the turntable does not have a pre-amp built in, so, this could be the way to go huh?
    Thanks and Regards,
    Scott
  5. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,335
    +4,209
    Again, it depends on your budget limits. If £20 is OK for you, then Richer Sound has a long history as a reputable dealer, and can certainly be trusted.
    However, if you can go as high as £40 to £60, there are a few other options.
    Really, all the pre-amp is giving you is the RIAA phono curve. Because bass signals cut such a wide groove in vinyl records, they had to cut down the bass and accent the treble. On playback, they run it all through a filter that is the exact opposite of the filter the used to cut the record. The reverse filter brings everything back to flat frequency response.
    RIAA equalization - Wikipedia, the free encyclopedia
    Steve/bluewizard
  6. Technics Scott
    Technics Scott
    Feb 12, 2009
    5
    4
    Kent
    Anyone else got any thoughts on this?
    Thanks,
    Scott
