suitable player
Discussion in 'Blu-ray & DVD Players & Recorders' started by novice2, Feb 7, 2005.
  1. novice2
    novice2
    I have just purchased a viera and want to upgrade on the dvd player. It needs to multi region and shouyld cost between £500 / 1000. If you could point towards the right thread I would very grateful (not had much luck with the search facility).
    Thanx
  2. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    You have quite a healthy budget there so you should be abloe to get a good player.
    What do you need/want it to do? what connections are you after?
    Do you want DVDaudio playback or SACD or both?
  3. novice2
    novice2
    Thanks for the reply Geezer
    Essentially I just want it to have component output to the screen with progressive scan (although the de interlacer on the viera is pretty good). I need optical or coaxial to the amp. I also want it to handle cds pretty well as I will be using it as my main CD player. I am just about to upgrade by speakers sub and sat only I am afraid as its a small room) and amp as well so any advice in that context would be helpful.
