Suitable budget amp?
Discussion in 'AV Receivers & Amplifiers' started by cool hand luke, Sep 11, 2004.
  1. cool hand luke
    cool hand luke
    Am thinking of going for the Mordaunt Short Premier speaker package and would appreciate some suggestions as to the amp i should be considering.
    The room size is 18'ft x 12'ft.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Hi Cool Hand,
    Errmm....What's your budget?
  3. cool hand luke
    cool hand luke
    Around £300 tops,will want to keep the rest for cables and stands etc.
  4. CosmicOne
    CosmicOne
    Look at the RXV650 i think i will be near ur budget & read the reivew of it's bigger sister the 750 here on HCCO they gave it 5stars & say it beat the rest in Stereo (the rest was HarmanKardon ,NAD,Marantz)
  5. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    Also consider the new Sony STR-795
  6. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Cool hand,
    You'll get a great deal more for your money if you look to second hand or at least exdem. You could be looking at a used DENON AVR 2803 or possibly a 3803 if your lucky. Considerably more amp for your money than the RXV650 (No offence guys!)
    Second hand amps are a pretty safe bet as there is very little that can go wrong with them. Secondhand in this pricerange is often a very good bet. A 12 month old (Obselete :laugh: ) amp can be snatched up for a fraction of the price.
    Worth a thought.
