Suggestions to replace aging Castle Speakers
Discussion in 'Home Cinema Speakers' started by Rich_ZT_CDTi, Jun 17, 2015.
  1. Rich_ZT_CDTi
    Rich_ZT_CDTi
    Dec 5, 2005
    230
    Dudley, UK
    +16
    Hi All
    Looking for suggestions to replace my ageing Castle speakers after one of the Avon cones finally died a death. The system currently consists of:-
    Castle Avons (L+R)
    Castle Keep 2 (Centre)
    Castle Dipole (Suround L+R)
    Castle Durhams (Rear Suround)
    CAstle Classic Sub (run of a B.K. Electrons board)
    They are currently being driven off a Arcam AVR500 and i intend to keep this.
    The room is about 5m x 4m and the distance to the TV/Centre is 4.2m
    I am thinking of the following:-
    M.A. New Bronze or Silver Range
    M.A. APEX
    I also have a possible option on the out going M.A Gold GXC150 and GX200 for the front and keep the rear set up as is.
    I am looking to inject a bit more life into the system. Budget is up to about £2k to do a full or partial replacement.
    What would people suggest i listen too or do with regards a full or partial update?
  2. DaneP
    DaneP
    May 13, 2015
    19
    London
    +3
    I can vouch for the MA Silvers driven by an Arcam receiver (I have the AVR400 + silver 6s & centre). They'd be a definite step-up from the bronze and if using for music then should comfortably out-perform the Apex. If you're a big music listener then you might want to look at the silver 8s.
    That all said, many seem to regard the gold series as a significant step-up over the silver (i haven''t heard them so can't comment) so likely worth trying to get a demo, particular given that you have a receiver capable of getting the most out of them.
    Keeping your rears for the time being shouldn't pose a problem, particularly if it frees up cash for better towers and a more potent sub.
  3. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
  4. Rich_ZT_CDTi
    Rich_ZT_CDTi
    Dec 5, 2005
    230
    Dudley, UK
    +16
    GX200 + GXC150 on their way!
    now GX50 or GXFX for the rears.........................
