Suggestions for surround sound amps?
Discussion in 'AV Receivers & Amplifiers' started by Fatman, Nov 6, 2004.
  1. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    Hi folks,
    I'm looking for some product suggestions for my home 'cinema'/TV setup.
    Existing equipment
    Cyrus 5
    Cyrus CD6
    B&W 603 S3
    Sony KV32FQ86
    Panasonic DVD-S75
    Humax PVR8000T (80Gb)
    Wharfdale NXT PP-S1 with sub
    So, I'm thinking about adding a surround sound processor/amp to that setup to drive the Wharfdales. I'd like to continue to play CDs through the Cyrus kit, so I guess the surround sound box will only be three or four channels (?).
    I've had a recommendation of the Yamaha DSPE800 which seems to allow what I want. Are there any other devices in a similar price range?
    Thanks! :)
  2. recruit
    recruit
    Not really unless you have a PC with a 5.1 soundcard and want to do it that way, the Yamaha is a good value processor and worth considering though or else you are going to have to spend quite a bit more money :(
    John
