SeanRo
Hello, I'm taking a break from my cinema build to complete a wood cabin/treehouse to be used as holiday accommodation. I'm just starting out on my [smart] lighting discovery journey and oh my - there is a lot to take in!
I'd ideally like simple wall mount switch panels that can handle multiple circuits, some in a multi way configuration (e.g. hall/landing) and am open to smart lighting or smart control of traditional lighting circuits. It's key that these panels are easy to use by visiting guests without an instruction manual or training, even if these systems can also be controlled by an app or voice!
The cabin will have a downstairs open space living/dining/kitchenette area with vaulted ceiling, a bathroom and bedroom, then spiral staircase to upstairs bedroom.
There are LED strip lights as well as mains LED bulbs to control. Dimming and the ability to control a circuit from 3 locations would be great. Open to soft panel or physical/touch switching
I'd be grateful for initial pointers to systems and manufacturers to look at. Bonus points if any configuration/programming can be done by my electrician or me (software developer)
Thank you.
Thank you.
