Suggestions for mid to high-end CD player?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by potterd, Apr 12, 2005.
  1. potterd
    potterd
    Hello all,
    Can anyone suggest a cd player suitable for a system based on the Tag av32r, PMC OB1s and Bryston PP120s?
    Thanks,
    Dave
  2. laalves
    laalves
    Feb 6, 2005
    493
    Cascais
    +8
    TAG 32FLR or CDT20L. Obvious choices due to the T2L link to AV32R.
    Luis
  3. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    Audionet Art V2
  4. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    Just seen a really good review for the copland CDA823 in Hi-Fi choice they gave it 92% which is very high for this magazine. I'm going to listen to one on Friday
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Potterd
    Just a check here, you have a set of Bryston PAs, a TAG AV32R acting a pre-amp – are you not happy with the TAGs CD performance as a DAC ? If you have separate PAs I would suggest avoiding a dedicated CDP and go for a DAC with a Pre-amp facility, Cyrus X-Dac Pre, Audio Syhtensis, Tact DAC-Preamp. I assume you have a transport already in a DVD player ? You can easily pick up a Chord DAC 64 for £1100 also heres a Mk II :
    http://forum.hifichoice.co.uk/viewtopic.php?t=16151
    If you are going down the Integrated CDP route, Coplands 822 & Sugdens Masterclass are very nice designs to these ears. But I would stick with the DAC side myself.
  6. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    The Audio Analogue Paganini Mk2 (in oh so classy jet-black) would be my choice. RRP £895.
    SO Italian and SO sexy. Phwoar!!
    DT
  7. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    DT the guy has got a AV32R already, Id be very surprised if that does not sound like a £1000+ CDP of today. As mentioned by Laalves - why not get an estoric DVD-V/V/SACD player to feed the AV32R, you can pick up Toshiba SD-9500s for £400 on Ebay.
  8. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Or better still a Shanling CDT-100 (wrong side of £1500 though :( ) - just pipe the valve output straight into your power amps - bypassing the AV32r altogether.......
    DT
  9. potterd
    potterd
    Thanks for the help. Will look into those options later.
    CJ, you are right - I should have specified CD transport or player. I have no problems in using the Tag for the DAC at this time although I am considering looking at other processors sometime in the distance future - to me the Tag does not give a very good 3D image. I am currently driving it with an old toshiba sd-3109 dvd player which is acceptable for movies, as far as I am concerned, but not for music. I was originally looking at a universal player so I could make use of SACD and DVD-Audio - in particular the 2-channel high resolution format - but I'm beginning to think that I'd be better off saving my money and going for a cheaper dedicated CDP/CDT. What do you think?
    Dave
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Dave if your considering other processors in future then IMO that rules out buying an integrated CDP now (waste of money) I also think you would need to spend upwards of £1500 to beat a AV32 in CD/DAC mode TBH. Maybe it’s the TAG Bryston combos not gelling well. Worth mentioning the Cyrus X-DAC-Pre again I feel, its just had a very good review as both a DAC and as a Digital Pre-amp in HFC – Im sure 7Oaks will do a demo, and funnily enough a friend also has a 3109 in tandem with a Cyrus AV5-Rotel PA that sounds pretty stunning to these ears :
    http://evildonut.34sp.com/systems/evildonut/index.html
    FWIW Ive always been a DVD-V+DAC user but a stereo only man myself, so I know where your coming from with the 2-channel hi-res angle. Simple truth though is that the writing is on the wall for both SACD/DVDA they will simply fizzle out. So I would concentrate on CD first. Saying that its possible to get a DVD-V/A player for pennies that does very well, Im now using my SD-9500 solely as my DVD-V & CD processor to my Primare, and damned fine it sounds. These can be bought for £399 off Ebay I believe many of us bought them around xmas time - heres some threads you may find interesting (as both a CDP & CD transport – 40spec jitter) :
    http://www.avforums.com/forums/showthread.php?t=56705 Gets interesting at page 8 onwards on the audio side.
    http://www.avforums.com/forums/showthread.php?t=188874
    Toshiba SD-9500 covers all your bases I reckon, you’re a Toshiba man already, it covers you as a top drawer transport jitter wise for future processors (if jitter concerns you), it’s a very decent CD player IMHO. DVD-V & DVD-A wise its also stunning in 2 channel mode (I run mine balanced to my Primare). Did I mention it has a PAL PS component output to die for.
    Finally I notice the PP120s also sport XLR inputs, then in future go for a DAC/Processor/Pre-amp with XLR outputs, Cyrus as mentioned seems to fit your bill, ie that it’s a DAC/Pre-amp with XLR pre outs, or once you sell the AV32R, buy an integrated with XLR inputs & pre-outs (TACTs Semi digital 1275 looks stunning VFM wise as do their DAC/Pres) and feed it from a XLR DAC, ie DAC 64 (£1100) or a Benchmark DAC-1 (£600).
    http://www.cyrus.co.uk/news/news_0804_8vs.htm#10
    http://www.movement-audio.co.uk/website/cyrus/cyrus-dac-xp.htm
    http://www.cyrus.co.uk/pigs/PIG - DAC XP.pdf
    http://www.tactaudio.co.uk/Products/S2150/index.html
    Anyway just some avenues to explore. HTHs.
  11. Icarus
    Icarus
    Which issue / month is that please?
