Suggestions for longer throw projector
Madders
Joined
Jan 30, 2002
Messages
2,762
Reaction score
74
Points
588
Location
London
Hi Guys,
I'm just trying to compile a short list of the best projectors to use in my setup. I'm looking at getting a 100" 16:9 screen and the projector would be mounted 7 metres back from the screen. What 1080P projectors would you suggest would work well within this setup? The room can be fairly well light controlled. DLP is not an option unfortunately as I see rainbow effect even with the latest 3 chip projectors. Budget would be up to around £2,500. What would you suggest....? :)
That's bizarre that you see the RBE from a 3 chip device, as it's the strobe effect from a colour wheel on a single chip DLP that causes the Rainbows?
Maybe you saw a 3 chip with really bad convergence? :)
Anyway, at that price you could pick up a good second hand JVC HD100 or a new HD1 (if you can find the stock).
These are very good PJ's and will project 100" at just over 6m... 120" at 7m.
There are very few projectors that will project a 100" (256cm) image at 7m.
Out of interest what was the 3 chip DLP product you mention above ?
Colour break-up aka rainbows is typically associated with using a spinning colour wheel to apply colour sequentially in a single chip DLP. Not all single chip DLP use the same type and speed of wheel so the phenomenon can vary from product to product.
AVI
Think it was a Marantz VP11-S2. Great picture otherwise.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
