Suggestions for a replacement amp?
Discussion in 'AV Receivers & Amplifiers' started by stretcher, Aug 11, 2002.
  1. stretcher
    stretcher
    Jun 25, 2002
    496
    Between Ashford (Kent) & Canterbury
    Hi folks - I wonder if anyone might have some advice or thoughts on an amplifier upgrade/replacement.
    My current system comprises the following Ruark speakers, which I am very happy with and don't intend to change:
    Fronts - Prologue One (pair)
    Centre - Dialogue One
    Rear - Epilogue One (pair)
    Sub - Log-Rhythm
    Just for interest, my TV is a recently acquired Loewe Aconda 9381 (2500 chassis), and the DVD player is a Techtronics modified Pioneer DV-717.
    The previous amp was a Yammy DSP A2 which has now been sold, but I am having trouble on deciding about a 6.1 EX , prologic II etc upgrade. My budget is about £750 to £850.
    Any thoughts would be most welcome.
  2. Guest
    My advice (the short version) is don't worry about 6.1 and try and get an ex-flagship Denon secondhand. Probably the best all round option for your money now.
    If you can get an A1D like the one I just sold you'll be smiling for a long, long time.
    A near-flagship 10SE just went on the classifieds here for £475 so one of them might be another option next time it appears. Again, a great amp.
    I had a DSP-A2 also and the Denon was a noticeably more listenable thing. I found the A2 cold and 'lifeless', the Denon A1D is anything but.
    HTH,
    Mike.
  3. stretcher
    stretcher
    Jun 25, 2002
    496
    Well, I must say that that wasn't an option I had considered, as the main reason the Yammy went was because I had particularly wanted to go down (or up) the 6.1 route!!
    Is the 6.1 upgrade not really worth doing? One of the amps I had been considering was the new Sony which seems to have had good reviews. But a bit pointless to spend all that money if there isn't going to be a significant improvement?
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    I can't comment on 6.1 as I only have DD at home, but I will say that you HAVE to get PLII -- it is the mutts nuts! Really brings Sky and my old VHS collection to life!:cool: Those with 6.1/7.1 say it is a step up from DD too. Depends if you have the room to accomodate them..
  5. stretcher
    stretcher
    Jun 25, 2002
    496
    I had picked up that there was 7.1 around as well - is this a true 7.1 channel split or is it a simulation like the Yammy did?
