Suggestions for a DTS ES 6.1 capable player
Discussion in 'AV Receivers & Amplifiers' started by KraGorn, Sep 8, 2003.
  1. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I'm trying NOT to ask a "which is the best" question here :) ... but I'd appreciate suggestions of machines to look at which can handle DTS ES 6.1.
    Currently I have a Nakamichi AV-10 which I love .. maybe that shows my lack of taste ;) .. but I want a second amp for various reasons and ES seems to be a sensible feature to have.
    Price isn't a big issue, that said I don't want to spend for the sake of it, but I don't see myself wanting to spend more than £750 without a good reason.
    The amp will be used with a front projection system, I have a set of Eltax 5.2s at present and for the foreseeable future won't change, I'll add an extra Eltax for the extra speaker.
    I don't want a receiver, just an amp, if all else is equal.
    Appreciate any ideas.
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Marantz SR 8300 or 9300 should be some bargains around at the moment. Alternatively wait a while for the 7400 may have Pro Logic IIx. or even the Arcam AVR300 not sure on price but should be a blinding amp for music and movies.
