Suggestions anyone?
Discussion in 'AV Receivers & Amplifiers' started by Finty, Dec 12, 2001.
  1. Finty
    Finty
    I recently bought a Marantz 4100 OSE - my first step into Home Cinema - and now want to complete a HC system.
    Unfortunately I live miles from a decent HiFi dealership so haven't had a chance to audition further equipment, but I've been impressed by the comments & reviews of the KEF 2005 eggs. They seem perfect, especially considering the size of my flat!
    However, things aren't so clear-cut when it comes to amps. Before I make a long journey with my hard-earned readies, I need some suggestions for amps to audition. Budget for amp & speakers is about 1600-1800 stg. So which amp suits the Marantz /KEF combination? Denon 2802? 3802? Marantz? Yamaha? Others? SHould I even be considering the KEFs?
    Any advice out there?
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Of the amps you´ve mentioned, i´d go for the Denon 3802.
    All the latest formats, sounds bloody good for both music & movies and will go well with the Kef´s.
    The Denon´s give you a decent setup menu as well for Delay times, channel levels etc. Its one of the reasons i changed from Yamaha stuff.
    IMHO the Denon´s sound better than the Yamaha´s, thats my personal opinion, others may disagree though!!
    cheers
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I agree.Get the Denon.
    I have a Denon avc11-sr(similar to the 3802)running with seven Kef eggs,and I'm pleased with the sound.
  4. Finty
    Finty
    Thanks Jase - and Simon! Denon it is then. If the bank manager gives me loads of dosh I'll go for the 3802. If he won't, would the 2802 match the Marantz and KEFs?
    Thanks again
    F
  5. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    You should be able to pick up the 3802 for around 600 quid.
    www.unbeatable.co.uk have it for around that.
    The 2802 is good but not as good as the 3802, the 2802 has less features etc
    Its worth the extra dosh, tap the bank manager for more!!!
    cheers
  6. Finty
    Finty
    Cheers Jase - I'll be in to tap the bank manager early next week. I think I'll bring a plumber pal o' mine...
    Unbeatable.co.uk have great prices - hundereds of squids cheaper than Ireland!! Thanks for that link. I await a quote on their delivery charges . . .
    All the best
    Finty
  7. ij
    ij
    Also have a look at http://www.hifijunkies.co.uk.
    Unbeatable price £633.96 + £34 = 667.96
    HiFi Junkies £640 including 3 year warranty
    Difference enough for a couple of DVDs - if you are interested in an extended warranty.
    HOWEVER I've been trying to phone hifijunkies all day, and the line has been engaged. There's also a lot of postive messages about hifijunkies in this forum, and I'd trust that more than my slightly bad one. (They are still getting my order - if I get through).
    And I've used unbeatable before, and they've been pretty good - but I do recommend you take the name of the agent if you need to speak to them on the phone - they do seem to suffer from corporate amnesia between calls.
  8. Finty
    Finty
    Sound! - thanks for that.
    Nice looking site that Hifijunkie - and good prices too. Shame they don't do the KEF 2005's.
    Still, if I use them I'll have loads of extra dosh to splash about in www.play247.com
    If you haven't been there, check it out - good site for DVD's. Great special offers!
    F
