suggestion for speakers
Discussion in 'Home Cinema Speakers' started by avforumssd, Mar 26, 2003.
  1. avforumssd
    avforumssd
    Hi!
    I dont know if this is the right forum, but please help me, I am terribly confused. I am planning to buy home theater equipment. Buying a yamaha 630 receiver (u guys recommend anything better?). I am confused about buying speakers, kindly advice:
    Room size: 11 ft x 12 ft
    Satellites or Bookshelf's or floor??? Suggest make as well. Budget around 1000 USD
    Already have yamaha S510 and Panasonic 29" Flat TV
    Thanks in advance
    SD
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,509
    7
    167
    Birmingham, UK
    +10,232
    Go to www.homecinemachoice.com and other home cinema related websites read some articles about and reviews of speaker packages so you know what's about.
    Then audition some speakers which are in your price range and buy the set which sound the best to you.
