suggestion for electric 100 inch screen for normal living room
Sunshinewelly
I currently have a standard white screen but have read that where light can not be controlled that a grey or even black screen works better.
i dont want to spend mega bucks for it though
any suggestions
chrisgeary
Take a look at Platinum Home Cinema, their matt grey screens work well in normal living rooms. They are budget so expect hot spotting and visible screen texture but the black levels will be way better than a white screen.
Sunshinewelly
i thought that these had poor reviews or will the issues with sparkles go if its tab tensions etc
sim12
No tab tension simply helps make the surface as flat as possible, the sparkles come from the texture of the material used.
Peoples reviews on these also put me off buying one, but i have also read that such as draper react screens have to be set up correctly to stop hot spotting, which then raises the question of have the reviewers actually got the pj's at the correct throw ratio to prevent hot spotting, sparkles can also show if viewing at more acute angles.
