Suddenly my self-burnt dvd's freeze and skip sometimes
Discussion in 'Desktop & Laptop Computers Forum' started by Tonvanrijn, Mar 9, 2006.
  1. Tonvanrijn
    Tonvanrijn
    Since yesterday I have a problem with burning dvd's. Since then I burnt 3 dvd's and all these freeze and/or skip at certain places.
    For a test I played a dvd that I burnt a few weeks ago and of which the video files were still on my harddisk. It played well without any problem. Then I made a new copy by burning it again and that one froze again at a few places. So the dvd player isn't the culprit and neither the files itself.
    I always burn at 2,4 speed with Traxdata dvdr's with a Plextor 708 and always stop unnecessary background applications/programs while burning.
    What could be the cause ? Is my dvd burner dying ?
  2. Boogie Badman
    Boogie Badman
    Feb 19, 2004
    1,785
    48
    Farnham Royal
    +41
    I have a similar problem, any advice would be a great help.
  3. parky43007
    parky43007
    Oct 8, 2003
    235
    Tarragona
    +16
    I had the same problem about a year ago. I changed my Plextor writer for a phillips and have not had a single failure since.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,778
    +3,190
    Any freezing or pixelating is due to poor media or burning too fast. I would suggest trying new media. Different burners like different media. What may burn rubbish on one, may burn fine on another. If you can afford them. Taiyo Yuden discs is about the best you can get.
  5. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    it sounds like the media, although it could be the burner. www.svp.co.uk has a 16x phillips burner for £20, and you can get £1.99 shipping if your a member of the buyers club (you can signup and get the code)
    if the disc wasnt authored correctly it wouldnt start to play at all, so it sounds like you have that part of things right
    another thing- have you checked the disc for fingerprints? give it a clean and see if it works. whenever my dad has a problem playing anything its cuz there are big mucky finger prints on the disc
    years ago when media was still new, most of the problems i had that you describe were down to poor quality media. i suggest you verify each disc after burning, so you know that the disc is burned ok. burning at 8x should be fine as long as the burner can handle a sustained 8x burn (ie. its not buffer underrunning)
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,778
    +3,190
    I wouldn't recommend the Philips at £20. I have read several bad posts about it and not one sucessful burn with it. It is a rebadged Liteon which a lot of their burners are not very good.
    I would go for one of the NEC's that SVP do.
  7. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    ah, i was considering spending £22 (inc delivery) as a spare/replacement for a cdrom drive. prices are coming down tho, so that might force pio and nec to push the prices down. liteon used to be alright (supposedly), but my standalone recorder is pants, i wouldn't recommend anything else of theirs as all i've seen in liteon forums is tons of people with problems
  8. luke.a.jones
    luke.a.jones
    Iv had problems with that before, have you tried a different media player? Solved the problem for me.
