Subwoofers.
Discussion in 'Subwoofers' started by grahambateman, Mar 29, 2003.
  1. grahambateman
    grahambateman
    Hi.
    I currently have an all mission set up , apart from the sub , which was a cheap aiwa. Should i upgrade this to a Mission , is so which one ( Under £ 300 ) , and if not a Mission , then any recomendations for alternate makes
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Are you happy with the sound from your sub? If not then upgrade.
    If you use the search function & search for something like "best sub" you'll find lots of threads where this has been discussed
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It isn't necessary to have a subwoofer from the same manufacturer as the speakers as the matching of voice coils is irrelevant for subwoofers.
    There has been a lot of discussion recently about subwoofers within this forum and there is a Velodyne model CHT10 that is available at a very competitive price in Power Buy forum and is only sklightly over your budget.
    Why not have a read through the threads from the last week covering the same subject.
    PS. I have moved your other two posts to Projector and DIY forums respectively where they belong
