Subwoofer Volume?
Discussion in 'AV Receivers & Amplifiers' started by Dr Downey, Jul 26, 2004.
  1. Dr Downey
    Dr Downey
    Jan 12, 2004
    122
    19
    Cheltenham
    Hi Guys,
    Please could you give me any advice as to the best way to set the subwoofer volume on my Sony HT-SL40? Is it just a matter of taste, or is there some method of calibration?
    Cheers!!
  2. cityonfire
    cityonfire
    When playing something with alot of bass say blade 2's club scenes or saving private ryan. As long as you cannot tell were the bass is coming when switched on and you are looking at it the sub directly it is set up right. Thats how i do it any how
  3. mikatt
    mikatt
    Dec 22, 2003
    176
    Hampshire UK
    +6
    Get the Digital Video Essential DVD from Piero Milani in the Power Buys does the job fine
    Mike
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    If you can notice the sub during normal listening, it is to loud.
    I agree with getting the DVE disk
  5. mikatt
    mikatt
    Dec 22, 2003
    176
    Hampshire UK
    +6
    Forgot to mention that you would need a sound meter to do properly such as the Radio Shack model
    Mike
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Agree with mikatt, you should use a test DVD and a SPL meter for proper calibration.
    Though instead of the DVD you could also use the test tones of the AV amp/receiver.
  7. Dr Downey
    Dr Downey
    Jan 12, 2004
    122
    19
    Cheltenham
    Thanks for the replies guys, DVE is now here!
    Cheers!
  8. SurferDude
    SurferDude
