Subwoofer tuning point- what is it?
Discussion in 'Subwoofers' started by nathan_silly, Mar 19, 2003.
  1. nathan_silly
    nathan_silly
    I've noticed the SVS subs are available with different tuned port configurations. What does this mean?
    Will the 25hz version not produce sound under 25hz?
    [edit] Been looking at the SVS CS-Ultra, pretty good spec- 12" driver, 1KW amp, $1300 + postage & import duty (bah)
    Anyone own this model? Is it great for AV?
    What is the overall build quality like? (is the cardboard tube thin?)
  2. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    I just found a PDF on their site that explains the tuning.
    With simulated response graphs! Port tuning PDF
    I understand what the the curves show but not why the port tuning alters the response curves.
    I am now thinking that a 25hz tuned model would do all that I need and save me some money.
  3. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
  4. nathan_silly
    nathan_silly
    Mat, I've read a bit about the different models- the 25hz versions will go louder, but not as low.
    Wheras the 16hz will go much lower than the 25hz version, but not as loud.
    I would say the 20hz model is the best, as most DVD's are in that area, and it only looses a couple of dB against the 25hz model (and possibly 25hz is a bit high anyway)
