Subwoofer - to swap or not
Discussion in 'Subwoofers' started by Pecker, Jan 1, 2007.
  1. Pecker
    Pecker
    Dec 26, 2004
    22,475
    Huddersfield, People's Republic of Yorkshire
    +4,587
    I have two A/V systems.
    My 'premier' system is my cinema room. The speakers are M&K K series, with a K-10 sub.
    My 'second' system is my living room. I have a set of Mordaunt Short speakers (2 floor standers for front L&R, a large centre, and 4 bi-/di-pole surrounds).
    To beef this up, by chance I have an old REL STORM sub.
    The M-S system is okay, but the bass is foundation-botheringly excellent.
    The M&K systam is crystal clear, but bass-lite.
    The obvious answer is to swap the subs. But will I have a convergence problem? The M&K sub was designed, after all, to go with the satellites.
    Another possibility is to feed all the M-S system's bass through the floor-standers, and move the REL upstairs to supplement (rather than replace) the K-10.
    Advice?
    Steve W
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    There are no tone matching problems between subs and their main speakers so it won't matter which sub you use as long as it goes as high as 80Hz - which all subs should do.
    Try the Storm with your M&K series and see if it does improve the bottom end. If so then you have a new dilemma :D
  3. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    I'd add that the K-series are pretty small and are likely to need a sub capable of low distortion up into the 150-200Hz region to integrate effectively. My Audyssey EQ see's my Xenons as needing a 200Hz x-over. I know people knock the cheaper M&K subs, but they are designed to do it.
    To see what else may be a candidate, check the various online sub tests and look particularly for subs that deliver low harmonic distortion above 80Hz.
    Russell
  4. Pecker
    Pecker
    Dec 26, 2004
    22,475
    +4,587
    Right, I swapped the subs, and here's what I find.
    The REL STORM, now with the M&Ks, usually sounds great.
    In fact it's always great.
    It's just that it sometimes sounds too directional.
    Logic tells me that the REL is having to go too high. I previously used it with the M&S florrstanders, which go lower than my M&Ks. I could subsequently set my amps crossover lower, the sub only had to output lower frequencies, and it subsequently drew less attention to itself.
    Solutions?
    Steve W
  5. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    Setting the crossover lower should cure the problem. I would sugegst trying it at 80Hz
