Around the web (and in my amp manual) I'm told that the ideal subwoofer settings (for stereo music) is to find set the subwoofer to only pickup sound where the speakers roll off. I've tried this and I don't like it:
1) If my sub only starts with freq below 50hz (the rolloff of my speakers), it's not very utilized in most songs. Then the songs turns really boring, I can no longer feel the 808/bassline.
2) so you might think, well THEN if you want more bass you can turn up the bass EQ/boost in the amp. But at the max of 10+db, that's not enough bass.
3) ..and what's worse, that kind of bass boost feels boomy. When I turn up the volume on the sub I'm loving the sound, but turning up the amp bass boost I hate that sound. My theory is that the amp is boosting too high freq of base, tho the manual says "+/- 10dB @ 100Hz" which does sound about right, but I don't know how wide that freq range is.
So in other words, I'm told that the sub should be for fixing the flaws of the speakers, whereas I use the sub for a completely different case, which is something like 120hz and max sub volume.
Song example: at 0:29 in this Avril song the bass line kicks in. On a subwoofer at 160hz this sounds great. But if I turn the sub down to 50hz and instead use the bass boost on the amp to hear that bassline, it sounds super boomy.
Gear:
*2x KEF Q950
*Cambridge ARX100
*1x SVS SB1000 subwoofer
Room: 40sq meters
I used to think that this method of "using the sub to boost all bass" was a necessary evil on low-end system, but if I ever buy a more proper system then you don't need it. But the gear above is my new setup and I find I still need the subwoofer to carry the song.
Gear:
*2x KEF Q950
*Cambridge ARX100
Room: 40sq meters
