Subwoofer to complete Home cinema
Discussion in 'Subwoofers' started by lunker, May 20, 2002.
  1. lunker
    lunker
    This is my first post so Hello!
    I've been considering a new sub to complete my Home Cinema. I've been considering either YAMAHA YST-SW105 SUBWOOFER or SONY SA-WM20B SUBWOOFER I've found numerous reviews but none of them conclusive. I want to spend about £100-£150 so can anyone recommend either of these or alternate for around the same price range.:confused: I don't need it to go that loud but I would like it quite deep.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Unfortunately, loud is cheap to manufacture but depth and precision are not. Have a look at the Paradigm range that Richer Sounds sell
  3. lunker
    lunker
    They don't have any Paradigm subs on the RS web site they do have a couple in the magazine I like the look of the £119 one. How much better is this going to be than the 2 subs I suggested and in what ways?
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Or you could stretch a bit and go buy the rel storm on www.hififorsale.com at £250......second hand
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The Paradigms have more precision than the Yamaha range but I'm afraid that I haven't heard (or heard of) the Sony.
    By far the best bet is the second hand REL Storm that buns pointed out which is a class apart.
  6. lunker
    lunker
    I tried both of my local RS both didn't have the Paradigm but suggested the Mordaunt-Short MSW20 at the reduced £130. How does this one compare with the Paradigm?
    £250 is a bit out of my price range.
