I have just completed my fall 2007 subwoofer tests. The following subwoofers (+ one speaker) were tested. The full results will be up when they are done.
Anthony Gallo TR-1
Audio Pro Level 110
BK XLS300/PR
BK Extreme
Gradient Evidence MKII
DIY CSS SDX15 sealed 100L
DIY CSS 2xSDX15 sealed 140L
DIY TC Sounds LMS-5400 18" sealed 100L
DIY TC Sounds LMS-5400 18" + 2x18" PR 200L
DIY Servo v2 (see. round 3)
JL Audio Fathom f113
SVS PB12-NSD
SVS PB13-Ultra (all four settings)
Velodyne SPL-1200 MKII
Yamaha YST-SW1500
Pictures!
Here are the results for the CEA-2010 standard I also used last time (round 4). I would recommend everyone to read this document regarding the standard. The CEA-2010 standard defines a new way for measuring and determining the clean maximum output level for a subwoofer. The signal used is a 6.5 cycle long sine burst which allows a safe measurement of the maximum output level. The max SPL is limited by the stepped distortion threshold (allows less distortion for higher harmonics) or the limitations/limiters of the subwoofer itself, which ever is reached first. The standard defines the max SPL normalized to 1 meter distance (half-space) and peak value of the sine burst, but I use the more familiar 2 meter distance and the RMS value of the sine burst. That way these figures are more comparable to the results measured by using the more common sine wave sweep/tone method.
The amplifier for all the DIY subwoofers (except the "DIY Servo v2") measured during round 5 was a Crown CE4000. The rated output at 4 ohms bridged is 3600 watts. With "DIY CSS 2xSDX15 sealed 140L" I used two of these amplifiers.
The "Gradient Evidence MK2" is a Finnish main speaker that I own (naturally a pair of them). I wanted to measure its bass performance because I haven't seen this kind of measurements done on speakers, even though their role in achieving well balanced sound system is absolutely critical. It is a 3-way speaker using a 6.5" coaxial driver and an 8" woofer in a ~35-40 liter ported enclosure. I used only one speaker during the measurements, but later on added 6 dB for the second speaker (assuming full coupling).
Below are the results for the newest (fall 2007/round 5) and the one prior to that (spring 2007/round 4) measurement session organized in "Low-bass Avg." (average of the 40-63 Hz values) column order.
Below are the results for the newest (fall 2007/round 5) and the one prior to that (spring 2007/round 4) measurement session organized in "Ultra low-bass Avg." (average of the 20-31.5 Hz values) column order.
Below are the results for the newest (fall 2007/round 5) and the one prior to that (spring 2007/round 4) measurement session organized in average of the 20-80 Hz order. I had to estimate the 20 Hz and 25 Hz values for the HSU MBM-12 and the Gradient Evidence MK2. I subtracted 9 dB from the 31.5 Hz and 18 dB from the 25 Hz values.
Anthony Gallo TR-1
Audio Pro Level 110
BK XLS300/PR
BK Extreme
SVS PB12-NSD
Yamaha YST-SW1500
Pictures!
