Subwoofer Test
Discussion in 'Subwoofers' started by Ian J, Jun 14, 2003.
  1. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I have been playing about trying to setup my SVS 20-39 PC Plus and have come up with the following graph.
    It looks to me like my next upgrade will be a BFD as the position of the sub is fixed due to it's size.
    I hope that you've got good eyesight as this is the maximum size that the software will allow
  2. nathan_silly
    nathan_silly
    Ian have you got a CD with test tones I can use to plot a graph? I've got DSL connection so I can download a CD ISO.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    The test tones can be downloaded from here
    Also available from the snapbug site is the draft spreadsheet which includes compensation for inaccuracies in the SPL meter
  4. tan1415
    tan1415
    What does the graph mean?
    I don't understand it...is it good or bad?
  5. nathan_silly
    nathan_silly
    My CD player doesn't playback MP3's. Are there any CD's with various frequency tones?
    I can't understand why the BFD doesn't come with a CD, or with built-in tones. I would be interested in the BFD it came with a CD, or a microphone auto EQ thingy like the DD-18 Sub or the Pioneer 2011 MACC.
  6. nathan_silly
    nathan_silly
    Tan, what Ian or anybody using a BFD is a flat response on the subwoofer- a perfect subwoofer/room diagram will be have a straight line at 75dB (or 85dB, whatever volume is used) from 20hz to 80hz, with no peaks or troughs. From Ians graph I (can't quite make out the numbers) is two peaks at 22hz and 40hz.
  7. tk2001
    tk2001
    Nov 4, 2001
    1,371
    48
    +36
    Ian J,
    Do you have your sub positioned in a corner of your room? I know SVS advises corner placement if possible for their subs.
    Are you playing those sine-waves at reference levels and jotting down the numbers?
    If you could iron-out the peaks at 22hz, 40hz, and 63hz then you'll be left with a very nice house-curve with very strong output from 16hz all the way up to 160hz, which only very good subs are capable of doing.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Sub is a foot out from the corner of the room and due to the size I am fairly limited as to where it can go anyway.
    I played the tones at reference level, wrote down the results and entered them into the Excel chart available from the snapbug site and that automatically compensates for the spl meter inaccuracies.
    I did the same thing with my old Storm but I am annoyed as I can't find it now :(
  9. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    9,996
    3
    +7,719
    Ian,
    That still looks like a very good response, a bfd will certainly be of great use and going by your graph it doesn't look like you should have too many difficulties taming the three peaks i see.
  10. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
    Can't you just put the tones onto a cdr,just make as an audio cd.
  11. Tom Vodhanel
    Tom Vodhanel
    Hi guys,
    Be CAREFUL with test tones of any sort. A sweep done at moderate levels is OK...but you'll need a RTA to plot that. (you can DL free RTA software now though if you have a PC near the HT system) Sine waves can fry a driver in a matter of seconds...so please, use very low output levels and try to get your measurement in a couple of seconds. (don't play the tone for 5 minutes while you are on the phone in the next room for example) and rest the subwoofer for 10-15 seconds inbetween each frequency you check.
    Tom V.
    SVS
  12. tan1415
    tan1415
    Oops.....
  13. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Ian
    I would agree with Phil, that, is NOT (by a long chalk) the worst native response curve i have seen, a BFD will certainly tidy it up but it's not going to overheat from workload.
    Steve.
  14. Tom Vodhanel
    Tom Vodhanel
    Hi guys,
    When you look at the graph, look for the maximum differences. In this case, I think it is 8dBs (forgetting about the big null in the 70-90hz range for a second). So that would be listed as +/- 4dBs...for in room response, that is actually VERY good. Adding an EQ to tame the two peaks would make it closer to +/-1 or +/-2dBs I think...even better. The 70-90hz null might be caused by some destructive interaction between the mains and the subwoofer. Try adjusting the phase control to see if you can tame that.
    if anyone wants to DL a kick-ass RTA, goto
    www.soundtechnology.com
    and DL the v4.32 software.
    It will work for 30 days on your PC, after that you need to buy the *key* to keep using it...I think I paid something like $3500...so be sure to take all the measurements you want within 30 days..:) 1/96th octave resolution, and ALL KINDs of capabilities....RT60, RTA, 3-D waterfall, ect. With this and a simple RS SPL meter, you can find out a LOT about your speakers/listening environment over a few weekends!
    Tom V.
    SVS
  15. nathan_silly
    nathan_silly
    I've downloaded SpectraPlus, I'm currently creating some Wav test tones.
    What type do I use? (pink, white etc) and shall I start from 10hz and do 20,30,40,50,60,70,80,90,100?
    What else shall I put onto a CD-R?
    [edit]
    I'm totally confused. Why aren't there CD's available with the tones you need for setting up a BFD & subwoofer available?
    I can use my PC from the optical output. What do I do to create the .Wav files I need?
  16. avanzato
    avanzato
    Jan 21, 2003
    1,940
    Norfolk
    +77
    I bought 'My Disc' a test CD from sheffield lab many years ago and it has helped me set up several systems.
    A long time ago I used it and a 31 band equaliser to do a rather crude EQ on a sub.
    You could try amazon for test CD's or your local Car audio shop.
  17. Tom Vodhanel
    Tom Vodhanel
    www.autosound2000.com
    test CD #101. $15
    It has sine wave from 10hz to 98hz (tracks 10 thru 98).
    Tom V.
    SVS
  18. petrolhead
    petrolhead
    Mar 29, 2002
    4,654
    Newcastle
    +103
    Nathan
    Apocalypse did a site re the BFD. On it was agreat link for the tones. All you did was download them (MP3) but then cut them to Music CD using Nero which converted them to CD format.
    I have found the origional post but the link no longer works so I have PMd him
  19. Steve Bate
    Steve Bate
    Nov 10, 2002
    677
    Tarporley
    +11
    Sineways download page here and this is the comprehensive setup guide originally in Apocalypses thread
    Hope this helps
    Steve
  20. JSW
    JSW
    Feb 21, 2002
    4,257
    Staffs
    +333
    Hi Ian,
    you can post a larger image is just how you reduce it that matters.
    If you reduced its size in a paint program so you could then save it with a low Kb count to be able to attach it then you get a small pic.
    The other way is to leave the size of the pic and reduce its dpi.
    Or upload your image to an image hosting site.
    Either way have fun with your new sub.
  21. NicolasB
    NicolasB
    Oct 3, 2002
    6,367
    Emily's Shop
    +843
    Really? How? I can see how a square wave would toast it, but a sine wave?
  22. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
    Yeah that is strange considering the tones last 10seconds and nobody as killed a sub yet.Well and not told us.If you want to see what response i got from the velo vx10 look here
  23. jag77
    jag77
    Sine waves can indeed kill the sub's VC. After a few minutes of playing sine tones at 80dB, the center of the SVS's metal cone feels warm to the touch. I can't imagine how hot it will be at the VC itself if I was playing them at 90dB longer than a few minutes.
    I read that when hot, the VC can vapourise its enamel, warp and permanent damage. Apparently, its not the case with normal sounds.
  24. tk2001
    tk2001
    Nov 4, 2001
    1,371
    48
    +36
  25. martintyler
    martintyler
    Sep 28, 2002
    120
    19
    London
    what software are you guys using to take these measurements?
  26. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
  27. martintyler
    martintyler
    Sep 28, 2002
    120
    19
    London
    I actually meant the software to record it and produce the graph... or did you just do that by hand, measuring each level and entering the spl into a spreadsheet?
  28. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Yes - measured by hand and entered into a spreadsheet that is available from the same website and automatically corrects for inaccuracies in the spl meter at low frequencies
  29. nathan_silly
    nathan_silly
    Ian have you fiddled with the variable phase, sub-sonic filter adjustments yet?
    So how much better is the 20-39 PC Plus compared to the Storm? For example, my Yamaha YST-SW40 is utter rubbish compared to the Storm. Is it the same again, Storm is rubbish to the SVS? Or is it slightly better?
    How many dB is it louder, does it chuff with Toy Story 2 intro logo, how much deeper etc?..
    Downloaded the tones, I'll be doing a graph today.
    [edit]
    Do I enter my results into the RAW values and leave COMP alone?
    Shall I use C weighting? fast or slow response?
  30. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    So many questions :D
    I haven't fiddled with the phase or filters yet but will have a go today. Sorry to be so slow but I watched Durham v Notts yesterday in between sunbathing and barbecuing instead.
    For movie use the 20-39 is in a different league to the Storm as it is much more powerful, deeper and produces cleaner bass. I don't play much music so am the wrong person to ask about that but the one or two tracks that I played sounded good. The Storm will be more versatile to connect up as all RELs can use the high and low levels connected together.
    You enter the values in the first column of the spreadsheet.
    I am hoping that Orbital, who lives locally and owns a Paradigm Servo will come round for a listen shortly and will report back to you all and Deckard who doesn't live that far away and owns a Velodyne CHT15 is also more than welcome to come round.
