Hi all. Just a quick question. I have the sub woofer with the built in amp.it has the 10 spring type connectors to connect the 5 surround sound speakers 5 on one side are color coded the 5 opposite are black marked center fr fl etc. Coming from each speaker i have the black wire and the other with the white stripe along it. Does it matter which side they go in on the sub woofer as there is nothing marked positive and negative.Appreciate any help.Thanks Dave.
