Subwoofer setup question...
Discussion in 'Subwoofers' started by jonnyv, Apr 12, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,280
    48
    +52
    Just bought a paradigm pdr10 to replace my yamaha sw90 subwoofer, Whats the correct way to set up the sub woofer as part of a home cinema system ?
    I have ran the test tones on my amp and used a sound level meter to adjust all speakers to same level, but the subwoofer tone makes the sound level meter needle move up and down and i cant get a level...Should i set the level by looking at the peak db when the needle is moving up and down ?
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,471
    Newcastle
    +291
    A SPL isn't necessarily that useful setting up a sub, because the Tandy one (I'm assuming that's the one you're using - it seems to be ubiquitous) is not that accurate at low frequencies. It reads up to about 11db too low - I posted a list of adjustments about a week ago. Again, this figure depends on the frequency, and the test tones are probably a mixture of frequencies.
    So, what to do?
    Well, you can try it by ear with music. The bass should be barely noticeable - but if you turn the sub off then there will be a significant difference. Sounds weird, but it's true.
    Hopefully someone with more experience of subs will come along and help you out more - I'm really just learning myself.
    Cheers,
    Liam
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,280
    48
    +52
    Thanks for your reply Liam, Could you post the list of adjustments again ?
    I Think ive got the levels right now, Its difficult to judge the levels by watching a film... following your advice..i put a cd on and it sounds about right..
    cheers
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,471
    Newcastle
    +291
    I originally posted them here.
    I've had a lot of MTV, VH1, Q music, etc on as well as CD's over the past week - I've made minor adjustments and I think it's not too bad now. Frequency response graph looks like something from Alton Towers, though :rolleyes:.
    Cheers,
    Liam
