Subwoofer setup question
Discussion in 'Subwoofers' started by slingshot, Mar 12, 2001.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'm having a slight problem setting up my sub which as IPL sub kit (hopefully I built it properly).
    I'm trying to use both low and high level input's the low level for cinema and the high for normal stereo. The high level is on a spare set of switched speaker outputs on my power amp (which just drives the main woofers).
    The problem is that the phase seems different between the 2. When using it with the high level input the phase needs to be reversed, otherwise it sounds like I'm getting less bass when I turn the frequency range up (I'm guessing that with the wrong phase setting it's cancelling out some of the main speaker bass at the crossover point). Has anyone come across this before and is there a reason or a solution for it ?
    Slingshot
  2. Jagular
    Jagular
    Hi Slingshot,
    That sounds fair. I've just built myself the SW2 and I'm over the moon with it.
    From what you've said; turn the crossover to the lowest frequency, turn down the low and the high level volume to minimum and begin by having the high level vol. at say 1/3. Bring up the crossover to just below your mains or to a point that doesn't cause room boom. Experiment with the phase; as in some circumstances you may need to cancel a peak if your room response is bad.
    Once set, try your Low-level volume. If this doesn't cut the mustard then the chances are your High-level amp feed is reversed. Reverse the Red and Yellow AND the phase switch and try again!
    Using X-Men THX Reference for the Bass sweep, mine goes right down to the bottom. Very satisfying!
    One or two minor dips and peaks from the room, but that comes later.
    Rob.
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    You mention the X-MEN frequancy thing, can you describe this in more detail.
    I have a REL Q100E and feel that it could sound so much better.
    Could you give me more tips on using BOTH connections
  4. Jagular
    Jagular
    Duncan,
    The X-Men Movie DVD has an Audio and Video set-up in its Special features. Good for setting-up Home Cinema Equipment. Just follow the on-screen instructions!
    It helps if you have an SPL Meter, but not absolutely necessary.
    Rob.
  5. Jagular
    Jagular
  6. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    I have the test tone you mentioned on many discs and have used the subwoofer test numerous times but have yet to really find out what it is for.
    When I play it there is never a moment when there is no noise ( well up until it finishes ) but as it get lower it does go in what I describe only as high/low waves.
    I have my roll-off set to max as this makes sure that the AMP does all the bass work and that the volume is at 75DB is there anything else I should do
  7. Jagular
    Jagular
    Duncan,
    Not sure what you’re saying about the amp doing all the work! Are you only using Low-level? If so, just use the High-level and try the roll-off lower until there is a hole in the response. Then bring it back up until the hole in the response is just filled.
    Rob.
  8. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    Hi guys,
    I too have just put together IPL sub and am extremely pleased with it. But, after reading the above am I right in thinking that the phase has to be correct for both high/low level and to do so the red/yellow wires have to go to correct r/l speaker outputs or can they go to either, I'm a bit confused with your advice./
    Philmate
  9. Jagular
    Jagular
    Sorry Philmate,
    Perhaps I'm clouding the issue here.
    When I replied to Slingshot, I was referring to a definite situation of incorrect amplifier phase output between speaker output and subwoofer (low-level) output.
    In practice this should NEVER happen, but I have had this happen to myself in the past.
    If the amp is wired incorrectly you will find that Bass will virtually disappear when the LFE channel kicks-in on DD5.1 or DTS. I don't expect this to happen!
    I hope I made this clear to Slingshot?
    Rob.
  10. Jagular
    Jagular
    When I refer to amp I mean AV amp, not subwoofer amp.
    Just thought I'd clear that one up.
    Phew! The deeper you go the deeper you get. (No pun intended.)
  11. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Thanks for the help I love the sub it's excellent, well up there with the Strata III I listened to.
    I tried your advice, however I still have the problem where the HC low-level processor output seems out phase with the high-level output from the stereo amp. It's not a massive problem because I can always switch the phase when I swop from cinema to stereo, however it would be nice not to have to bother walking all the way over to the sub.
    I tried swapping the red and yellow on the high level but this seem to have no effect, so I wondered wether I could rewire the low-level lead and swap one end round so that red and black are swapped, would this swap the phase around for the low-level input ?
    Slingshot
  12. Jagular
    Jagular
    If you've already tried reversing the phase on the high-level and it didn’t work there’s no need to do anything else, just restore them to original, the phase isn’t the problem. Sounds like the set-up. Have a word with Ivan; I'm sure he can sort you out.
    Just a thought, are your Main speakers in phase?
    Rob.
  13. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    I have my sub connected only by the phono connection. I have set the roll off to max as I was under the impression that my amp ( a denon a1d ) will do all the work of deciding what frequancies should be sent to the sub and so the roll off has to be on max else bass sounds will be lost.
    I was under the impression that the roll off controlled how much bass the sub produced and if set too high with speaker connections the bass can be overblown, but with the phono I thought that the amp made sure that there was never too much bass
  14. Jagular
    Jagular
    Duncan, there are many different viewpoints on this subject, this is just mine:
    There’s nothing wrong in just using the low level -if you’re satisfied- with the crossover in the AV amp cutting out the bottom end of your main speakers performance. The general consensus for Hi-Fidelity is to allow the main speakers to naturally roll-off and use the subs low-pass (crossover) filter control to bring the bass frequencies up to meet them. This way you are not affecting the main speakers design performance. If you require the Low Frequency Effects channel for HC use, adjust the volume for the low-level separately. Some subs have a by-pass for the LFE input, some don’t, but don’t worry too much if yours doesn’t as the LFE track information on Dolby 5.1 cuts off dead at 120Hz, so a smooth roll-off of LFE from around 80Hz can give a nice blend into the main cannels.
    Rob.
  15. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    Ok, I think im staring to understand.
    The problem with the REL Q100E is that the roll off is only marked MIN or MAX
    I need the info in as simple as terms as possible so am I correct in thinking I should......
    Connect the sub by the SPEAKER CONNECTIONS only to start with. Set the subs volume to the same as the front speakers ( 75db in my case ) and then play the sub test. Now I should increase the Roll Off until there are no gaps in this test. I should then leave the Roll Off in this position ( if it helps I have B&W 603s2 speakers ) I also assume that I should now set my front speakers to LARGE.
    Now I should connect the sub back up with the phono cable as well and set the volume for this back to 75db as well.
    Is this correct ????
  16. Jagular
    Jagular
    YUP!!! You've got it!
  17. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    Ok after much fiddling I have set my sub up as described above.
    I have the sub connected with BOTH connections and the volume for both inputs set to 75db.
    I also set the front speakers to large as I assume the whole thing would be pointless without doing so.
    Now im still confused about the roll-off. The test tells me that I need to get an even sound with no gaps, but no matter if I have the roll off at min or max there is always a continues sound. At min there does not seem to be that much action from the sub, with only a tiny bit of rumble, but with the roll off set to max there seems to be lots more rumble but the bass does not seem overblown.
    Is there any chance that there is anybody else with a pair of 603s and a REL Q100 ? If so how do you have your roll off set ?
    Also just from the tiny demo I had with this new set up I have found it to sound better this way
  18. Ramius
    Ramius
    Oct 13, 2000
    1,082
    Yorkshire
    +308
    Duncan
    I'm curious as to why you think your sub could/should be performing so much better.
    What are you unhappy about?
    SPL?? Extension?? ??????
    Can you feel an upgrade coming on?? [​IMG]
    Cheers [​IMG]
  19. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    The main thing is that I have heard q100s sound much better than this.
    Im very happy with those low rumbles that are produced but am still trying to obtain those hard slams and crunches ( skull crush on T2 ) that I had in the demos before purchasing
  20. Jagular
    Jagular
    Duncan,
    I know this sounds obvious, but you have got the cinema EQ set to OFF, the LFE at ZERO and Tone controls FLAT have you not?
  21. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Rob ,Ihave the Xmen DVD Region2 Icant find
    Audio Setup in Special Feature ,Any Help
    Anv help would be appreciated .
    Jim
  22. dUnKle
    dUnKle
    Jan 1, 2001
    15,474
    +2,381
    The THX opti-mode settings are only on the r1 version
  23. Ramius
    Ramius
    Oct 13, 2000
    1,082
    Yorkshire
    +308
    So Duncan, you're happy with the low rumbles but not getting the midbass punch.
    Could be a room null.
    I was in one with the first position of my sub. It was difficult to tell by ear. I still had plenty of bass impact but I knew something was not perfect.
    So I plotted the subs response at the listening position, 16-80Hz in 2Hz increments. Low and behold there was a 20dB null at 42-48Hz. Sounds a bit like your scenario.
    I moved my sub to the other side of the room and now it plots pretty flat. The difference in sound was amazing.
    Something for you to do this weekend. [​IMG]
    If you go here- http://members.tripod.com/~terryctheater/shivaphotoalbum/page12.html
    At the bottom of the page you'll find some files containing various test tones you can download and use. There's a MP3 file for specifcally manually charting and plotting (15-80Hz Sweep, 1Hz increments 5 seconds each).
    These are the correction values for the inaccuracies of the Tandy (RadioShack) analogue SPL meter.-
    10Hz add 20
    12.5Hz add 16.5
    16Hz add 11.5
    20Hz add 7.5
    25Hz add 5
    31.5Hz add 3
    40Hz add 2.5
    50Hz add 1.5
    63Hz add 1.5
    80Hz add 1.5
    100Hz add 2
    Doing all this will be very helpful even if it's not a room mode problem.
