Have denon2500 amp and monitor audio mass speakers 5.1. Not the new ones. Setting up with audessy was simple enough but on test tone there is nothing from the sub. Appears to be working, but have I done something incorrectly. Using LFE on sub, phase set to zero, vol on sub 12 position and crossover at zero as I understand this is taken over by amp when on LFT.
I also noted the automatic set up set the sub to -6db, I’ve since upped this setting to around 2-3db. What should I tinker with on the amp or sub to improve bass if required.
John
John
