Big Simon
Established Member
Hello Sir,At the amplifier end of the Neutrik cable there are three bare wires. Twist the single black (i.e. -ve) one of these wires with speaker wire that goes into one (doesn't matter which) of your -ve banana plugs for your main L/R speakers.
Twist the other two Neutrik cable wires with the speaker wires that go into the +ve banana plugs of the main L/R speakers.
So at the end three of your banana plugs will have an additional wire coming out of them. One of the negative ones will not.
Are you with me?
Was chatting to BK Electronics today re the XXLS400-FF re the wiring of the high end cable and it appears following clarity i can use the spare 'B' speaker terminals. They followed it up with an email as follows:
"The high level lead comes with Speakon plug that connects into the subwoofer and three bare wire that connect to the speaker terminals on your amplifier. I have Googled your amplifier and see that it has 2 sets of binding posts. This gives you more options, you can put the bare wires straight into the binding posts and screw them down and if you are using Banana plugs on channel A then you can either screw the wires down on the binding posts or put Banana lugs on the bare wires".
They said this negates the need to twist cables together etc and simply to select both 'A' and 'B' speakers on the front of the AMP.
For a dumb ass like me, this would be simpler lol, lol.
I assume this means i will have one of the terminals free as there are only 3 wires. Hopefully this ties in with your own thoughts.
Really appreciate all your help to date, its been invaluable in helping both my own knowledge and to help make an informed decision.
Simon.
