Subwoofer questions
Discussion in 'Subwoofers' started by dwsadler1, Sep 5, 2001.
  1. dwsadler1
    dwsadler1
    I am considering the following subwoofer options (£300 imposed limit) to go with my KEF Q setup:
    Monitor Audio ASW 100<br />Eltax Atomic A-10<br />KEF 20 B<br />KEF 30B<br />B&W ASW 1000
    Any comments from excited/disappointed users?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Where can you get the B&W ASW 1000 from for £300?
    The ASW 500 is the closest to the £300 mark at £350.
    Highly recommended though.
  3. Guest
    if it were my money: Forget the Eltax and listen to the rest, they're all O.K.
  4. dwsadler1
    dwsadler1
    My mistake!<br />It was the B&W ASW 500 I saw for £350 (a justifiable stretch over the imposed limit of £300.
    Any thoughts on the Monitor Audio sub?<br />What is wrong with the Eltax?
  5. tfraser
    tfraser
    You could build your own as I am: see
    <a href="http://www.iplacoustics.co.uk/ipl_sw2_active_subwoofer.htm" target="_blank">http://www.iplacoustics.co.uk/ipl_sw2_active_subwoofer.htm</a>
    I hope to finish next weekend. It will cost £300 and I'm looking forward to hearing it for the first time while I watch U571 dvd for the first time!
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    The 30B is going cheap via various vendors ie, Superfi etc. Scan through a copy of What HiFi for the box shifters.
  7. Dan_BlitzedS14
    Dan_BlitzedS14
    I think I'd go for the B&W but you'd be wise to listen to them.
    Also, check with Kef on this one but I don't think they make the 20B anymore and I know they don't make the 30B now.
    Dan
  8. mark.king
    mark.king
    Listen to the man with the ipl sub. I have one of these and it is a class above anything you can buy for £300. I have had a rel straterIII at home to try and although I could not test both together I was not disapointed when I finished the ipl kit. The finish you can get with the iron on veneers is so much better than the cheap finishes on £300 subs. I also added spikes from maplins later on which firmed up the bass more.
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    <a href="http://www.bkelec.com/Diy/sub.htm" target="_blank">http://www.bkelec.com/Diy/sub.htm</a>
    The bass amp unti used on the IPL sub, only £117-ish
  10. mark.king
    mark.king
    sounds about right as the total kit is round about<br />£270 with the speaker and pre cut wood and high level input lead. Still does not leave much for profit.
  11. dwsadler1
    dwsadler1
    Please Let us know how your DIY sub turns out
  12. mark.king
    mark.king
    Mine is built and I have been using it for about six months. I had no problems building it. I did not screw the cabinet together but glued it and it is air tight.
    Excelent sound for the price and looks really good with a real wood veneer stained to whatever you like.
