Subwoofer Problems
Discussion in 'Subwoofers' started by LyfeIs, Jun 2, 2008.
  1. LyfeIs
    LyfeIs
    Jun 2, 2008
    I'm having a problem with my Supercube II. At first I thought it was a faulty sub, but recently, Def Tech sent a brand new Supercube and it still doesn’t work.
    This is a list of the issues I've had:
    First time I sent it back was because the right passive radiator was damaged.:confused:
    Second time, the left one was damaged.:eek:
    Third time the main sub was busted.:mad:
    They sent me a new one and when I plugged it in there was a pulsing sound coming from it. The second time I turned it on the pulsing noise was gone but now there is no noise coming from it at all. It doesn’t seem to be working.:suicide:
    I’m using a Yamaha HTR-5960 to power it and a Monster THX LFE cable.
    Any suggestions or ideas on why I'm experiencing this?
