Minivan
Hi Everyone,
I'm moving into a new build and having the flooring installed before we move in. I won't get a chance to have a play with speaker positioning first as the speaker cable is being installed under the flooring.
If you see the attachment, the neighbours are on the other side of the right hand wall.
My question is, will the positioning of the sub effect how much bass might travel through the wall? It's a new build and conforms to regulation E, which I believe is pretty good sound proofing, so hopefully they won't hear much.
Any advise welcomed.
thanks
John
thanks
John
