Subwoofer "Popping"
Discussion in 'Subwoofers' started by ronyart1, Jun 27, 2003.
  1. ronyart1
    ronyart1
    Hi All
    I dont know if you can help but I have the Kef system and everynow and then the Subbase seems to "pop" for example when the music for The Bill plays. Is this because it has just received a signal and jumped into life or do i have one of the settings wrong such as the crossover frequency??
    If anyone else experienced this I would be most grateful.
    thanks
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    does this sound like the same pop when you first switch your sub on? I very occasionally hear this and have put it down to noisy mains.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    If the sub has an auto facility it will pop when the sub first receives a LFE signal if it has been dozing for a while. If you can switch the auto facility off, do so
  4. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Another possibility is if the sub is actually working the popping sound could be from the sub's speaker hitting its end if the bass signal is especially large.....I had one of the smaller Kef subs a while back which did this with regularity.
  5. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    Don't think the theme from the Bill is particularly bassy though!
    :p
  6. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    LOL,Adam....you're very probably right in terms of depth...if the signal was of relatively large amplitude irrespective of frequency...in any case I dont watch the Bill(and would prefer it no to watch me either!....the Old Bill that is.)
