Subwoofer output not working!
Discussion in 'AV Receivers & Amplifiers' started by oitzjake, Sep 14, 2018.
  1. oitzjake
    oitzjake
    Oct 29, 2017
    4
    4
    Grimsby
    Hi there, I recently purchased a used Pioneer VSX-922K AV receiver and have had multiple issues with it, from the right channel being quiet (tapping the back panel usually sorts it) to it randomly turning off and requiring unplugging to get it back on.
    The only issue I have been unable to find a fix to is that neither of the subwoofer outputs work correctly. I am using an external car amp which has a built in dB volume level indicator, and this was pulsing with the music using my previous receiver, but with this one it remains with a constant signal. This signal remains even when the reciever is on standby, but the subwoofer plays nothing as if it were either high in pitch or some form of incorrect signal. Either way the signal never changes whether playing music or not. Any suggestions would be greatly appreciated as I have sold my previous receiver and do not want to give up this one!
    The subwoofer did seem to react to the auto-setup with the mic, but it seemed to output audio on every channel test. This is the only time it has ever made a noise with the amp.
  2. dante01
    dante01
    Mar 5, 2009
    44,839
    +10,532
    2 channel audio doesn't include an LFE channel that would ordinarilly be present with multichannel film soundtracks so the sub will not be active while dealing with 2 channel sources unless you designate your speakers as being SMALL and assign them crossover points at which to redirect frequencies away from the speakers to the sub.
  3. oitzjake
    oitzjake
    Oct 29, 2017
    4
    4
    Grimsby
    Thank you for the response, this is the case with HDMI audio too. Using an Xbox One and the output is set to 5.1 audio in the settings, this did work correctly with a previous receiver.
  4. dante01
    dante01
    Mar 5, 2009
    44,839
    +10,532
    It would be the same if accessing 2 channel sources via HDMI, but if using an upmixinh mode then that mode should create an LFE channel for use by the sub.
  5. oitzjake
    oitzjake
    Oct 29, 2017
    4
    4
    Grimsby
    It is not just 2 channel, it is within movies and games. The rear and centre speakers are working, but the subwoofer remains silent. The level indicator on the amplifier remains at the constant level.
  6. JamesMcG3
    JamesMcG3
    Sep 24, 2018
    4
    Montreal, QC
    I have a Pioneer VSX-01 where after a few years the sub out simply died. I found one thread on here with others that had the issue and I gave up. It's dead, and not worth repairing. So I'm stuck using the pre-amp outputs on my receiver to the line level in on my sub. It works well enough, and I'm just lucky my sub amp happens to have that input method...
  7. oitzjake
    oitzjake
    Oct 29, 2017
    4
    4
    Grimsby
    Thank you for your response. Unfortunately this amp doesn't have any other outputs. I believe it to be dead and wouldn't be surprised if the rest of it was judging by its issues :(
