Something we have discussed before is that some AV Recievers/Processors will clip the subwoofer output when turned up.
This clipping from an AVR is low level signal level clipping and thus while sounds bad is not dangerous at all.
High level clipping i.e the clipping you get from overdriving an amplifier past it clean limtis is a very different thing and is dangerous due to the increaced power.
As I just got a new portable scope I set to testing the subwoofer output on my Denon AVR-1802.
To test you need 0db test tones to unsure you can drive the system to its maxumim level.
I disconneted the RCA from my subwoofer amplifer and connected the scope to it.
I set the Subwoofer level to 0 and AVR the master volume to 00.
I played a 20hz tone and observed...no clipping.
Next I upped my subwoofer trim level on the Denon till it read +12db result....no clipping.
That is good news. I also tested in Stereo and Prologic II just to check...yes all fine.
I then upped the master volume to 02 and it was clear that the output was starting to clip as I upped it to 06 the output clipped hard.
I then backed the master volume back to 00 and tested at 30hz, 50hz and 80hz to enure it was clean. They were all clean, at 80hz it was clear on the scopes trace that the onboard crossover was starting to attenuate the output.
So to conclude my old Denon 1802 does not clip the subwoofer output at all unless you push the master volume past 00 and have the subwoofer trim level at +12. They have done a good job in setting up this classic AVR.
I wonder if your AVR/Processor also do not clip? I may have to test some more!
Here are some pictures.
AVR Master level 00 (and subwoofer trim level +12).
19hz on the edge of clean.
20hz clipping.
20 hz clipped hard.
50 HZ starting to clip.
50hz Clipping.
50 hz Clipping hard.
20hz clipping.
20 hz clipped hard.
50hz Clipping.
