Subwoofer or floor standing speakers?
Discussion in 'Home Cinema Speakers' started by smike.jones, Nov 28, 2004.
  1. smike.jones
    smike.jones
    Nov 26, 2004
    If anyone has any advice on the problem below I would greatly appreciate it.
    I'm currently using Quad 11L speakers with a Musical Fidelity XA1 amplifier and a Sony XA20ES CD player, and I find the sound too bass light for my taste. I'm considering adding a sub such as a MS309 but I'm worried the sound of the sub and the speakers won't match each other. Would I be better off selling the 11L's and buying some more bass capable larger speakers, or would adding a sub solve the problem without losing the 'hi-fi' sound?
    The system is used mainly for music and not for home cinema.
  2. ttree sound
    ttree sound
    Oct 17, 2004
    367
    +13
    I recently upgraded my PMC DB1s which are a similar size to your Quads, to a front pair of PMC FB1 floorstanders. These have a much greater bass extention, but even so I cant for the life of me think why anyone would want to use any standmounter without a sub. I use these floorstanders with a Rel q400e sub and the cumilative sound is awesome, far more intimate than using the stereo pair alone. I would go so far as to suggest that if you dont use a sub you will be missing out on a great deal of enjoyment from the extra frequency range that a sub brings.
  3. recruit
    recruit
    Hi Smike,
    If you are really only useing you're system for Music then Floorstanders are a good option, When the 11L's 1st came out i had a pair in an Hi Fi only setup and felt i needed more bass just like you so i bought a Rel Quake and added that bit more Depth to the Music and Bass, In the End though i ended up selling my 11L's and sub and bought the 22L's which gave me alot more bass and was very happy, I suppose it is all down to preference and what or should i say how much Bass you like!!!
    If i was you i would get some Dems of the 11L's with a sub like the New Rel stampede which is very easy to intergrate into a music setup & also get some dems with just Floorstanding speakers and see what you prefer!!!
    John
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You shouldn't have a problem adding a sub to your system as tonal matching isn't really a problem at those low frequencies.
    Most of the discussion here is about adding subwoofers to AV systems and this is done using a low connection to the subwoofer output on the AV amp.
    As your amp is stereo only you will need to connect at high level (speaker level) and many subs don't offer this facility so you will need to be careful which sub you buy. REL and MJ Acoustics are particularly flexible in connection terms so both should be high on your list to have a closer look at.
    You won't lose your "hifi sound" as the sub will take over where the Quad's begin to lose their oomph
  5. Mandel
    Mandel
    Subs are good for sub frequencies. They tend to produce a strong yet muddy bass effect. If you're mainly a music type then I'd strongly suggest buying floorstanders. I used standmount speakers with a sub for a quite a while till I discovered that the sound was actually clearer without the sub, and preferable despite the loss of some sub punch.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I think you've been listening to the wrong subs or else they haven't be set up correctly. Mine produces very sharply defined notes.
  7. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    mine does too :)
  8. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Mine does three :D
    I would say keep the Quad 11L's, they are great speakers and add a sub, the BK XLS200 would be a perfect match, it's quick, punchy and will integrate well with the 11L's, I'm not sure if it has high level speaker connections though.
    Another option, although more expensive, is to go for the Quad L subwoofer, which would be a sonic and aesthetic match, I've heard both the BK and the Quad and both are fantastic. I wasn't impressed with the REL subs I heard at the recent what hi fi show, and one of them included the stampede, I think the Quad L subwoofer will give you a better performance per pound solution.
  9. recruit
    recruit
    Sometimes running a Sub in a Hi Fi only setup is not always the best answer and the only way to know is try both!!
    I prefer the sound just with my Floorstanders gives me enough bass for music :)
    John
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The BK XLS200 does have a high-level input via a locking Neutrik connector, along with seperate gain controls for high and low level imputs.
    Definitely a very musical option that's easy to integrate, is very small and shouldn't break the bank. :)
  11. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Another approach, one that I would look at rather than the sub option would be to add a power amp to the system especially for music only use. By doing this you are effectively doubling the power to your speakers. In reality this means the bass is tighter, better controlled and packs more punch but without the excessive weight often produced by subs.
    Just another way of attacking the same problem.
