Subwoofer on laminate
Discussion in 'Subwoofers' started by stefmcd, Jan 21, 2005.
  1. stefmcd
    stefmcd
    Nov 7, 2004
    591
    +7
    Should I remove the speaker feet/spikes?
    Just set up my system and placed the sub towards a corner - very boomy effect. Spikes or positioning? THing is the sub looks cool on the spikes and they are not sharp enough to damage floor but if they're spoiling sound then they have to go.
    Its a CAnton CD1 system btw.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Try moving it out of the corner. I doubt whether it is the spikes making it boomy but more likely positioning, setup or a comnination of both.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    Keep the spikes and splash out 8p on 4 2p coins to put underneath them.
  4. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Try putting some thing heavy on top of the sub as well. Laminate floor can be a pain as I've found out already.
  5. y220186
    y220186
    Dec 24, 2004
    38
    Might try the something heavy on top as mine travels around the room on its own.
