subwoofer not waking up ??
Discussion in 'Subwoofers' started by jont, Oct 31, 2003.
  1. jont
    jont
    Apr 8, 2002
    4,268
    near Aylesbury
    +553
    Noticed my gallo sub is feeling a bit lazy at the moment and doesn't kick in when I switch the amp on ...
    Sometimes it takes a change in the sound mode before it works, sometimes it will kick in 15-20 mins through a cd on normal stereo or from another source ...
    Its connected through single phono from AV8 ... not sure if its a problem with the sub or a problem with the AV8 ...
    Any ideas ?
    cheers
    Jon
  2. kenlong69
    kenlong69
    Oct 24, 2002
    508
    Doha
    +6
    Hey there,
    I'm not familiar with the gallo sub but most poeple find subs to be more responsive if you get a Y connection for your amp and use both left ad right inputs on the sub... that's assuming there are left and right inputs on the sub.
    Ken
