slim01
Can hear/feel a very light humming sound coming from it as I turn the volume right up to max. Then pops a little when switched from on to standby and goes off.
Makes a massive pop if you unplug the rca whilst it's on (yeah, oops).
Tried cable in l r and also with the y splitter.
No change.
On the receiver...
Set to direct, from the pc as always have it (its getting dolby digital live from my pc, and I use eq settings from my asus xonar dx sound card):
When sub is set to yes I get to change fronts to large or small.
Option appears called "double bass" when speakers set to large.
All do nothing to the sound of the KEFs (to my ears).
Speaker distance:
Does nothing to the sub.
Tried sp config...
Sub From 0 to -15 to +15, no change.
Crossover from 40hz to 200hz
Changes nothing.
It worked at the guys house. Don't see how it could have got damaged on the way to mine.
I know it's plugged in ok because it marks a farty noise when playing the 5.1 test sound from amp or windows or from the amps test tones for level calibration.
No change.
On the receiver...
Speaker distance:
Tried sp config...
Changes nothing.
