DodgeTheViper
So I've been messing about with cardboard again and thought I'd build a PB-3000
Not entirely accurate but not far either.
Looks like a perfect match![]()
It does fit in pretty well. I just wouldn’t get it in white![]()
There's at least 2" at the top and 3"-4" to the side, don't forget you will be always wondering what the 16" ULTRA sounded like![]()
Nice job Kev.
No white would be a bad choice.
Have you ever considered painting your skirting boards? My walls need painting again but I really can't be bothered. I'd love a nice stretch fabric wall finish.
No, it’s too deep to fit in.
Yeah I have thought about painting them but not sure I’d want them the same colour as the walls. As for that bloody rug though . . .![]()
Smaller black rug with enough room for the 16![]()
I’ll see if I can mock up a PB16U tomorrow.
It certainly can go loud. Wonder about other qualities.Or Monoprice 15 THX! Why? Because you get PB4000 performance for lower price than PB3000. With extension down to 10hz which the PB16U can´t even do.
Chucky7 at AVSF had it for while. He has full JTR system.
I reviewed the Monolith 15" in my HT for about a month. It is an excellent sub. The Monolith 15" hit 105dB @ 11Hz and almost 113dB @ 14.5Hz in my 22' x 14' x 7.5' family room...
What about the PB-4000 ?It's a nice thought but they really would be too deep.
I prefer real subs not ones made from cardboard
It might work out better for your wallet Dodge to simply break down one of the walls and extend your extension than chopping and changing all the time.
Better yet create a separate room, stick the subs in it, punch a couple of holes in the wall and you've got yourself a sweet IB system.![]()
The SB3000 looks tiny in comparison, no wonder they are so popular for integrating into smaller spaces and rooms.So I've been messing about with cardboard again and thought I'd build a PB-3000
I can only accommodate 1 sub unless I do some diy and a new floor, I’ve kinda forgotten about the PC 2000 in the front left corner, I don’t play movies that loud but enjoy the very low frequencies it can go down to on the occasional movie.
I was thinking about changing my PC-2000 for a PB-3000 but they are so deep it would have to face the TV unit and not out into the room although there would be a decent gap between them.
I also came across the review of the PSA S1512 on here, that looks like a huge performer in a small box, I think you had the S1500 ?. That took me to the PSA V1512 but it’s obviously much taller than the sealed unit. I can only accommodate 1 sub unless I do some diy and a new floor, I’ve kinda forgotten about the PC 2000 in the front left corner, I don’t play movies that loud but enjoy the very low frequencies it can go down to on the occasional movie.
Im using a couple of these black rugs, they have a rubber type backing so don’t slip on wood or laminate floors and for the money not to bad quality, a few different sizes too.
Amazon product
I had forgotten you have a projector, what did you go for ?.
