marvintheandroi
This is more a Hi-Fi question than AV, but hopefully you'll forgive me and someone can help.
I have recently purchased a Wharfedale SW-150 subwoofer which is being driven by my old Technics SU-A700 MK3 stereo amp. Very happy with it.
However I am getting a pronounced and clearly noticeable mains hum when the Technics amp is powered off.
I am considering getting some shielded speaker cables with a shield wrap that could be earthed to ground, in the hope that this might eliminate or reduce the induced current in the conductors. eg https://www.audiophonics.fr/en/cabl...e-ofc-2x25mm-frnc-shielded-o-83mm-p-9922.html
Does anyone have any experience of this approach, and it it likely to work ? Anyone got a better idea ?
The long term solution is to save up for a new amp with sub out, but that isn't on the cards for a while.
Need help.
Thanks.
- The subwoofer is connected from my amplifier “B” speaker output to the speaker level input connections on the subwoofer. I use 2.5sq mm pure copper speaker cables and banana plugs. Both left and right channels are connected.
I do not have sub out on my amp. - The hum stops immediately when the amplifier is powered up, even if no source is playing. I guess the amp is grounding the negative cables but only when switched on.
- The hum still occurs if I remove the speaker cables completely from the back of the amplifier.
- The hum stops if I remove the speaker cables from the back of the subwoofer.
- This is clearly an induced current in the connecting wires which, being speaker cables, are unshielded - and then gets amplified by the subwoofer. I have tried moving them away from any mains cables and using a different (UK) mains socket for mains power but it persists.
Need help.
Thanks.
