subwoofer line-in
Discussion in 'Subwoofers' started by ste_hewson, Jan 14, 2002.
  1. ste_hewson
    ste_hewson
    and currently testing the mordaunt short premiere package at home and have a small question abou the sub. my amp has a sub pre-out but the sub has left AND right line inputs. will either of these inputs work the same?
    It's also got high-level input and satelite terminals to loop these through but am not using these.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Use either.
    Subwoofer manufacturers don't seem to be very good at explaining all of the options in the manuals as my REL QBass also has two inputs which are not mentioned.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,665
    Manchester suburbs...
    +204
    As far as i know, the left channel into the sub is the mono input, so that would be the one to use! Can anyone confirm this?!!
  4. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,479
    Inbetween Upgrades !
    +7,753
    dts_boy,
    You are quite right. The left channel is the mono channel and so is the one to use for your sub.
    Kev
  5. ste_hewson
    ste_hewson
    cheers, I'll check that out
