jonjames
Established Member
Can I just check, once Audyssey has been run, I get a result of -7.0db. Sub dial is about 10pm. You can then alter the level by using the subwoofer level adjust under audio in the avr menu. By default it is off. If I turn this on and have it at 0.0db (default value), has this then added 7.0db I presume? Likewise if I set it at -3.0db I have added 4.0db?
Is this the right way to do it as I have been reading people use the channel level adjust under manual speaker settings, then levels.
