subwoofer in movies works more like a room vibrator rather than a speaker and in music it is nonexistent
and7
I have a 12' dedicated subwoofer in my living room, XTZ 12.17 edge (left port open, reference eq setting) paired with Yamaha rxv 581. On the one hand sometimes it sounds amazing, especially in movies during deep bass scenes whole room is shaking including me, on the other hand sometimes bass is nonexistent. I understood that something was off when I listened to familiar music, bass was not there. Listened the same songs in my pc crappy speakers with a 4’ sub driver and the bass reproduction was 10 times better than my dedicated system. Don’t get me wrong I don’t say that pc speakers sound better I say that I can hear the bass notes everywhere in the room loud and clear in opposite to my dedicated system that I cannot hear the bass anywhere in the room, not even next to the sub. Tried to rerun ypao , tried to turn off the eq , tried to boost 40-70 hz frequencies from my subwoofer eq , tried different eq options, tried to open and close the ports with the sponges that came with the sub, I did the sub crawl test , I raised the volume, changed the phase , changed the 90hz crossover setting, tried almost everything but nothing works for music . In movies there are times that the room is vibrating like earthquake but most of the times I feel the bass I do not hear it . There are scenes that I understand that I had to hear the boom and then feel it but I just feel the vibrations more than I hear the subwoofer. Is it normal? I know that you cannot hear deep bass you can just feel it but I think that i should be able to hear the mid and upper bass especially in music. To conclude I think that the subwoofer in movies works more like a room vibrator rather than a speaker and in music it is nonexistent .
AmericanAudio
AVForums Sponsor
First question, are your front speakers set to Large or Small.
In my Yamaha amp, with them set to Large it cuts out 90% of the bass being fed to the sub, regardless of the crossover settings.
sm1ggsy
Hi, Peaks and nulls is probably the problem, you really need a mic and rew. Sub crawl is flawed you can’t pick up on all frequencies
and7
Doing subwoofer freq sweeps (-20db volume) without using a mic just my ears, i can hear the sub from 20hz to 100hz clearly. There are some minor audible loudness differences but i think that those are not enough to cause such problem. At -20db volume, 20-35 hz are not loud enough, 40hz and above are louder. I think that its normal considering that deep bass needs more volume in order to feel it. I am afraid that i will damage the sub if i do the sweep in higher volume .
mb3195
You can’t tell by listening the way you are . Your sub should be able to go up to -0db on your receiver.
The only way of knowing is as @sm1ggsy has said. REW and a UMIK-1 mic.
Dolus
Looking at it another way, it is not unusual for music to not have as much bass compared to films. I experience the same thing. My PC speakers sound as if they have more grunt on music. It is not unusual for small speakers with limited bass extension to have a boost built in at the mid bass frequencies, so the bass sounds bigger and better.
Edit another point. I don't know how the Yamaha works, but on my Denon but if I play a stereo file, (two channels), in direct mode then the subwoofer is not engaged. I have to choose the stereo option to get stereo with the sub playing.
aekostas
Sorry I am coming in late. Did you get to the bottom of it? I too would eliminate the listening mode first.
